Hi everyone
I have a couple of questions.
A) can vero plays this files in real hdr?
CONTENEDOR: MKV
CODEC DE VIDEO: x265 HDR
FRAMES DE VIDEO: 23,976
RESOLUCIÓN DE VIDEO: 1920x816
BITRATE DE VIDEO: 11951.37 kb/s
AUDIO 1: Castellano DTS 5.1 @ 768 kbps -> UHD
AUDIO 2: Catalán DTS 5.1 @ 768 kbps -> UHD
AUDIO 2: Inglés DTS 5.1 @ 1509 kbps -> UHD
SUBTÍTULOS: Castellano forzados, Castellano completos, Inglés completos
TAMAÑO: 9,50 GB
Format : Matroska
Format version : Version 4
File size : 10.5 GiB
Duration : 1 h 38 min
Overall bit rate : 15.3 Mb/s
Encoded date : UTC 2019-01-18 21:32:29
Writing application : mkvmerge v30.1.0 (‘Forever And More’) 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 12.0 Mb/s
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.318
Stream size : 8.20 GiB (78%)
Writing library : x265
Language : English
Default : Yes
Forced : Yes
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
B) if I have a full 4k disk, vero detects it in the library but doesn’t play, I have to open the file manager and select the main .mts file to start playing it with no info about audio channel or subs. It’s my file bad or I’m doing something wrong?
Thanks. Cheers.
