Hey all
I’m having issues playing back Howl’s Moving Castle on my Vero 4K +.
Sometimes it weirdly stutters in scenes that should be fluidly.
The file is being streamed over the local gigabit network but running it through usb also shows the issue.
Automatically adjusting the framerate doesn’t fix the issue.
File info:
Codec: H264 - MPEG-4 AVC (part10) (avc1)
Frame rate: 23.976216
Decoded format: Planar 4:2:0 YUV 10-bit LE
Logs:
Here are the logs: http://paste.osmc.tv/oyurikedog
Here is a video recording of the stuttering, albeit micro in this recording: - YouTube
Here is a clip to check for yourself. a short video file showing correctly on VLC on PC but not fluid in Vero 4K+: MEGA
