2.5G LAN adapter?
I recently upgraded my home network to 2.5G. All units in the chain are 2.5G except for the Vero V.
There are several 2.5G USB adapters on the market. Is it possible to use any of those to get 2.5G network in the Vero V?
Just be aware that the most common chipset for 2.5Gbps USB adapters, RTL8156B, often has issues where it goes to sleep when there’s no traffic and doesn’t reliably wake up.
More importantly, if you’re just streaming content from a NAS, there’s no content available today where 1Gbps isn’t more than enough. So the only reason to have it is if you’re moving files to/from the Vero.
I see. Thank you.
Possible yes, but 2.5Gbps is a lot of throughput.
Are you running Vero V as a NAS?
If you’re just using it for playback, you will not hit any limitations with the 1Gbps integrated PHY.
