Hi. When I select a drive and bring out context menu, there are 2 ‘remove safely’ options. Both work. Maybe just a skin problem. Either way it’s just a minor thing.
This is a Kodi issue as the safely remove option is part of the context menu which only Kodi has control over. Skins don’t.
Ah. I should report to Kodi?
