Hi I’ve got a RPI2 and I recently upgraded from 2016.06-2 to 2016.08-1 and now Yatse can’t skip to next track or previous (every other button works). I updated Yatse but still no luck. I’ve got another PI2 with 2016.06-2 installed and skip track works fine on it.
The skip button in confluence skin works ok.
Any idea what’s causing it?
Log shows
ERROR Playlist Player: skipping unplayable item: 6, path [musicdb://songs/2472.mp3]
WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
ERROR: CAudioDecoder: Unable to init Codec while loading file musicdb://songs/2472.mp3
ERROR: init: Error opening file musicdb://songs/2472.mp3
Shouldn’t it use the full SMB location of the MP3? why is it using musicdb://songs/ ??
Thanks.
