In the system settings, this rate isn’t listed as a desktop setting. Is it actually supported when playing content? I know my TV shows both 24 and 23.976 content as 24Hz so I can’t determine the actual rate.
thanks.
edit: I know that 905X chip is perfectly capable of this so my question is about the current OSMC release
Yes.
AML SoC uses a framerate automation technique. As long as you have Adjust Refresh Rate enabled you will get 23.976Hz output. Most people can tell pretty quickly if 23.976Hz isn’t working.
Thanks, output looked pretty smooth to me but I just wanted to be sure. I guess that I’m a bit spoiled by MadVR’s very detailed on screen statistics…
