i think you’re right! thank you.
Yes, I haven’t had time to look at it, but that issue is still on my todo list
Thanks for thinking about it. This will make my user experience of the Vero perfect!
Run:
‘sudo apt-get install --reinstall vero3-mediacenter-osmc’
With any luck, a few weeks. I wanted it to be ready for end of next week, but we’re coming up against some tough bugs.
Oh, cool.
Keep in mind that we want it to be as good as our current kernel is – so this takes time.
We know how fussy you are
If you need any updates on the timeframe, let me know.
Don’t tempt me.
Hi there,
I am following the development of the 3D topic since quite a while and was happy to hear that the frame packed output seems to be implemented now.
I followed the explanation to update to the November version.
My current findings are:
- When opening a 3D MKV, i have the choice to select hardware acc…
- A small info box informed me, that 3D playback is starting, using the hardware
…unfortunately it does not… I am using a SONY VPL 260…
Same files do work properly with a Raspberry Pi and KODI.
After that I tried to follow the next recommendation by adding
and starting the update process. After the update was finished, I did not have the choice of hardware… any more. So I re-installed the previous November version as describe above.
But again no success. Any idea what I could do additionally?
Thanks, Tabaluga73
Please post some debug logs so we can see what’s going on and check if you are on the right version
Hi Sam,
thanks for the quick feedback. Could you briefly link me to the topic, what kind of log you need and how I activate it?
Thanks Tabaluga73
Edit:
I did some further tests and found out the following:
Having set the system to UHD leads the player to display 3D-top-down instead of packed frame. Setting the system to FHD leads the player to play the file but you just hear the sound, the picture is black…
Here some extra of the KODI.log, hope that helps:
Summary
2019-11-21 20:44:25.935 T:4071067648 NOTICE: -----------------------------------------------------------------------
2019-11-21 20:44:25.936 T:4071067648 NOTICE: Starting Kodi (18.5). Platform: Linux ARM (Thumb) 32-bit
2019-11-21 20:44:25.936 T:4071067648 NOTICE: Using Release Kodi x32 build (version for Vero)
2019-11-21 20:44:25.936 T:4071067648 NOTICE: Kodi compiled 2019-11-17 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.110 (264558)
2019-11-21 20:44:25.936 T:4071067648 NOTICE: Running on Open Source Media Center 2019.11-1, kernel: Linux ARM 32-bit version 3.14.29-156-osmc
2019-11-21 20:44:25.945 T:4071067648 NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-11-21 20:44:25.945 T:4071067648 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
2019-11-21 20:44:25.945 T:4071067648 NOTICE: ARM Features: Neon disabled
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://envhome/ is mapped to: /home/osmc
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
2019-11-21 20:44:25.945 T:4071067648 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
2019-11-21 20:44:25.945 T:4071067648 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
2019-11-21 20:44:25.945 T:4071067648 NOTICE: Local hostname: Vero4K
2019-11-21 20:44:25.945 T:4071067648 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
2019-11-21 20:44:25.945 T:4071067648 NOTICE: -----------------------------------------------------------------------
2019-11-21 20:44:25.945 T:4071067648 INFO: loading settings
2019-11-21 20:44:25.946 T:4071067648 NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-11-21 20:44:25.971 T:4071067648 DEBUG: CSkinSettings: no tag found
2019-11-21 20:44:25.972 T:4071067648 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-11-21 20:44:25.972 T:4071067648 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Current display setting is 0192001080059.94006istd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Current output resolution is 0128000720060.00000pstd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Fallback resolution at 16 + 0 00480060.00000pstd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Fallback resolution at 16 + 2 00576050.00000pstd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Fallback resolution at 16 + 3 00720050.00000pstd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Fallback resolution at 16 + 4 00720060.00000pstd
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2019-11-21 20:44:27.145 T:4071067648 NOTICE: Fallback resolution at 16 + 6 01080024.00000pstd
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Fallback resolution at 16 + 8 01080050.00000istd
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Fallback resolution at 16 + 9 01080050.00000pstd
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Current resolution setting found at 16 + 11
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 50.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 60.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 59.940060 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2019-11-21 20:44:27.146 T:4071067648 NOTICE: Found best resolution 0192001080059.94006istd at 27, setting to RES_DESKTOP at 16
2019-11-21 20:44:27.146 T:4071067648 ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap_3d
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 1470 with 1280 x 720 @ 50.000000 (FP)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 50.000000 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 50.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 1470 with 1280 x 720 @ 60.000000 (FP)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 1470 with 1280 x 720 @ 59.940060 (FP)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 60.000000 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 59.940060 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 60.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1280 x 720 with 1280 x 720 @ 59.940060 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 2205 with 1920 x 1080 @ 24.000000 (FP)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 2205 with 1920 x 1080 @ 23.976025 (FP)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 (TAB)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 (SBS)
2019-11-21 20:44:27.147 T:4071067648 NOTICE: Found 3D resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 (SBS)
2019-11-22 16:57:18.472 T:4071067648 NOTICE: VideoPlayer::OpenFile: smb://3D.mkv
2019-11-22 16:57:18.474 T:3920622304 NOTICE: Creating InputStream
2019-11-22 16:57:18.548 T:3920622304 NOTICE: Creating Demuxer
2019-11-22 16:57:18.859 T:3920622304 NOTICE: Opening stream: 0 source: 256
2019-11-22 16:57:18.865 T:3920622304 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
2019-11-22 16:57:18.865 T:3920622304 NOTICE: Creating video thread
2019-11-22 16:57:18.866 T:3452953312 NOTICE: running thread: video_thread
2019-11-22 16:57:18.867 T:3920622304 NOTICE: Opening stream: 1 source: 256
2019-11-22 16:57:18.867 T:3920622304 NOTICE: Finding audio codec for: 86020
2019-11-22 16:57:18.867 T:3920622304 NOTICE: Creating audio thread
2019-11-22 16:57:18.867 T:3920622304 NOTICE: Opening stream: 5 source: 256
2019-11-22 16:57:18.868 T:3534201568 NOTICE: running thread: CVideoPlayerAudio::Process()
2019-11-22 16:57:18.982 T:3534201568 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, pass-through)
2019-11-22 16:57:19.169 T:3452953312 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
2019-11-22 16:57:19.935 T:3452953312 ERROR: CAMLCodec::AddData: packet to big: 249742, probably corrupted
2019-11-22 16:57:25.890 T:4071067648 ERROR: Previous line repeats 3434 times.
2019-11-22 16:57:25.890 T:4071067648 NOTICE: VideoPlayer: OnLostDisplay received
2019-11-22 16:57:26.126 T:4071067648 NOTICE: VideoPlayer: OnResetDisplay received
2019-11-22 16:57:39.640 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 16:57:39.640 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
2019-11-22 16:57:39.642 T:3920622304 NOTICE: CVideoPlayer::OnExit()
2019-11-22 16:57:39.642 T:3920622304 NOTICE: Closing stream player 1
2019-11-22 16:57:39.642 T:3920622304 NOTICE: Waiting for audio thread to exit
2019-11-22 16:57:39.694 T:3534201568 NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-11-22 16:57:39.695 T:3920622304 NOTICE: Closing audio device
2019-11-22 16:57:39.738 T:3920622304 NOTICE: Deleting audio codec
2019-11-22 16:57:39.738 T:3920622304 NOTICE: Closing stream player 2
2019-11-22 16:57:39.738 T:3920622304 NOTICE: waiting for video thread to exit
2019-11-22 16:57:39.749 T:3452953312 NOTICE: thread end: video_thread
2019-11-22 16:57:39.750 T:3920622304 NOTICE: deleting video codec
2019-11-22 16:57:39.878 T:3920622304 NOTICE: Closing stream player 3
2019-11-22 16:57:39.994 T:4071067648 NOTICE: VideoPlayer: finished waiting
2019-11-22 16:57:39.994 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 16:57:39.995 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
2019-11-22 16:57:39.995 T:4071067648 NOTICE: VideoPlayer: finished waiting
2019-11-22 16:59:20.111 T:4071067648 NOTICE: VideoPlayer::OpenFile: smb://3D.mkv
2019-11-22 16:59:20.113 T:3688956640 NOTICE: Creating InputStream
2019-11-22 16:59:20.174 T:3688956640 NOTICE: Creating Demuxer
2019-11-22 16:59:20.533 T:3688956640 NOTICE: Opening stream: 0 source: 256
2019-11-22 16:59:20.533 T:3688956640 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
2019-11-22 16:59:20.775 T:3688956640 NOTICE: Creating video thread
2019-11-22 16:59:20.775 T:3461346016 NOTICE: running thread: video_thread
2019-11-22 16:59:20.776 T:3688956640 NOTICE: Opening stream: 1 source: 256
2019-11-22 16:59:20.776 T:3688956640 NOTICE: Finding audio codec for: 86020
2019-11-22 16:59:20.776 T:3688956640 NOTICE: Creating audio thread
2019-11-22 16:59:20.777 T:3452953312 NOTICE: running thread: CVideoPlayerAudio::Process()
2019-11-22 16:59:20.777 T:3688956640 NOTICE: Opening stream: 5 source: 256
2019-11-22 16:59:20.883 T:3452953312 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, pass-through)
2019-11-22 16:59:20.887 T:3461346016 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
2019-11-22 16:59:21.717 T:3461346016 ERROR: CAMLCodec::AddData: packet to big: 170045, probably corrupted
2019-11-22 16:59:24.065 T:4071067648 ERROR: Previous line repeats 1159 times.
2019-11-22 16:59:24.065 T:4071067648 NOTICE: VideoPlayer: OnLostDisplay received
2019-11-22 16:59:24.306 T:4071067648 NOTICE: VideoPlayer: OnResetDisplay received
2019-11-22 16:59:40.769 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 16:59:40.770 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
2019-11-22 16:59:40.777 T:3688956640 NOTICE: CVideoPlayer::OnExit()
2019-11-22 16:59:40.778 T:3688956640 NOTICE: Closing stream player 1
2019-11-22 16:59:40.778 T:3688956640 NOTICE: Waiting for audio thread to exit
2019-11-22 16:59:40.783 T:3452953312 NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-11-22 16:59:40.783 T:3688956640 NOTICE: Closing audio device
2019-11-22 16:59:40.830 T:3688956640 NOTICE: Deleting audio codec
2019-11-22 16:59:40.831 T:3688956640 NOTICE: Closing stream player 2
2019-11-22 16:59:40.831 T:3688956640 NOTICE: waiting for video thread to exit
2019-11-22 16:59:40.842 T:3461346016 NOTICE: thread end: video_thread
2019-11-22 16:59:40.845 T:3688956640 NOTICE: deleting video codec
2019-11-22 16:59:40.890 T:3688956640 NOTICE: Closing stream player 3
2019-11-22 16:59:41.002 T:4071067648 NOTICE: VideoPlayer: finished waiting
2019-11-22 16:59:41.002 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 16:59:41.002 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
2019-11-22 17:00:45.325 T:4071067648 NOTICE: VideoPlayer::OpenFile: smb://3D.mkv
2019-11-22 17:00:45.327 T:3368022752 NOTICE: Creating InputStream
2019-11-22 17:00:45.403 T:3368022752 NOTICE: Creating Demuxer
2019-11-22 17:00:45.739 T:3368022752 NOTICE: Opening stream: 0 source: 256
2019-11-22 17:00:45.739 T:3368022752 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
2019-11-22 17:00:45.745 T:3368022752 NOTICE: Creating video thread
2019-11-22 17:00:45.745 T:3415208672 NOTICE: running thread: video_thread
2019-11-22 17:00:45.746 T:3368022752 NOTICE: Opening stream: 1 source: 256
2019-11-22 17:00:45.746 T:3368022752 NOTICE: Finding audio codec for: 86020
2019-11-22 17:00:45.746 T:3368022752 NOTICE: Creating audio thread
2019-11-22 17:00:45.746 T:3461346016 NOTICE: running thread: CVideoPlayerAudio::Process()
2019-11-22 17:00:45.746 T:3368022752 NOTICE: Opening stream: 5 source: 256
2019-11-22 17:00:45.836 T:3461346016 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, pass-through)
2019-11-22 17:00:45.837 T:3461346016 ERROR: CAEStreamInfo::GetDuration - invalid stream type
2019-11-22 17:00:45.845 T:3415208672 ERROR: Previous line repeats 1 times.
2019-11-22 17:00:45.845 T:3415208672 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
2019-11-22 17:00:46.830 T:3415208672 ERROR: CAMLCodec::AddData: packet to big: 137398, probably corrupted
2019-11-22 17:00:47.785 T:4071067648 ERROR: Previous line repeats 558 times.
2019-11-22 17:00:47.785 T:4071067648 NOTICE: VideoPlayer: OnLostDisplay received
2019-11-22 17:00:48.016 T:4071067648 NOTICE: VideoPlayer: OnResetDisplay received
2019-11-22 17:00:48.029 T:3415208672 ERROR: CAMLCodec::AddData: packet to big: 137817, probably corrupted
2019-11-22 17:00:48.047 T:3415208672 ERROR: Previous line repeats 2 times.
2019-11-22 17:00:48.047 T:3415208672 ERROR: CAMLCodec::AddData: packet to big: 139554, probably corrupted
2019-11-22 17:01:01.896 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 17:01:01.897 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
2019-11-22 17:01:01.898 T:3368022752 NOTICE: CVideoPlayer::OnExit()
2019-11-22 17:01:01.899 T:3368022752 NOTICE: Closing stream player 1
2019-11-22 17:01:01.899 T:3368022752 NOTICE: Waiting for audio thread to exit
2019-11-22 17:01:01.900 T:3461346016 NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-11-22 17:01:01.900 T:3368022752 NOTICE: Closing audio device
2019-11-22 17:01:01.948 T:3368022752 NOTICE: Deleting audio codec
2019-11-22 17:01:01.949 T:3368022752 NOTICE: Closing stream player 2
2019-11-22 17:01:01.949 T:3368022752 NOTICE: waiting for video thread to exit
2019-11-22 17:01:01.963 T:3415208672 NOTICE: thread end: video_thread
2019-11-22 17:01:01.965 T:3368022752 NOTICE: deleting video codec
2019-11-22 17:01:02.100 T:3368022752 NOTICE: Closing stream player 3
2019-11-22 17:01:02.210 T:4071067648 NOTICE: VideoPlayer: finished waiting
2019-11-22 17:01:02.210 T:4071067648 NOTICE: CVideoPlayer::CloseFile()
2019-11-22 17:01:02.210 T:4071067648 NOTICE: VideoPlayer: waiting for threads to exit
reboot the OSMC device
reproduce the issue
upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
Hi Sam,
I uploaded a log for the 4k. If it is still needed, I can post you the URL… BUT: I found the problem:
It is not just about the resultion but also about the frequency. My KODI starts regularly with 3840x2160@60Hz. Switching to 1920x1080 did not solve the issue as the frequency was still set to 60Hz. Changing the frequency in the system to 23.98 did solve the issue!
Means in other words: OSMC (or KODI?) should recognize the correct resolution / frame rate and change it for playback. Would that be possible?
Thanks, Tabaluga73
Do you have settings>player>videos>adjust display refresh rate> set to On start/stop and sync playback to display disabled? Do you have anything set in the whitelist. If you have the former enabled, and your whitelist empty, then it should adjust to a resolution and frame rate appropriate to the source.
Even if you’re not trying to play 3D material, that’s probably not a good idea. The Kodi UI on the Vero 4K is designed to run at 1080p; and videos will probably look better if you output them at native resolution and let the TV upscale.
It will if you set the resolution to 1080p and enable Adjust Refresh Rate
No, thanks for that. That helps to adjust the frequency correctly.
Not being that deep in the details, but what about 4k material if KODI runs at 1080p? Will it recognize the correct resolution? I just wonder having my experiences with 3D in mind, where KODI did not change the resultion down to 1080p from 2160p.
Yes, after you have configured
OSMC will switch resolution and refresh according to the Video material being played. As of now (due to the quality of the Upscaler) it is recommend to keep the GUI at 1080p
To clarify this a bit further. When you enable adjust refresh rate video (without a whitelist) video at or below your UI resolution will output at your UI resolution at the closest matching frame rate your display supports. Video that is a higher resolution will be output at the higher resolution. That is why having a 4k UI set prevented HD output of your 3D source.
The only exception to this is when you use a whitelist which allows, depending on how it is configured, to switch to resolutions both above and below the UI resolution.
That makes things quite clear. Thanks to all for your support. I will switch my UI to 1080p, knowing that 2160p movies will still be displayed at 2160p.
Is there a kind of explanation about whitelists in the forum and how to set them up?
Thanks to Sam and all the developers. I am quite happy that 3D frame packed is working and that I do not need to run to players for now!
Thanks, Tabaluga
To best of my knowledge nobody has written one up either here, on the Kodi forum, or anywhere else. The basic bit is you select every resolution and frame rate that you want output. If your TV has a very good upscaler this may give a superior output. The not so basic bit is the UI is also affected while the video is playing and between that and using overscan on your TV for 4:3 content… well you just have to play with it a bit and find out for yourself. It is not something that most people would actually want to do, but it is good to have options for people who want to squeeze the most out of their high end displays.
