Has anyone been able to play 3d from iso’s.
Not sure if it is supported, cant find any real info about it.
Regards
Regards
No. Convert to mkv with makemkv and make sure stereo video stream is enabled. (This is a quick operation and doesn’t transcode). Name the file with “.3d.sbs.” in the filename and make sure MVC is enabled in video acceleration, and “adjust display refresh rate to match video” is also enabled.
There is experimental ISO support in Milhouse nightly builds (openelec) but not in any OSMC builds currently.
It will appear in stable OSMC builds at some point in the future, but probably not until Jarvis (it is still experimental).
Thanks a bunch!
Must have missread somewhere and thought it was possible. Spent hours trying to get it to work
