Hello,
I’m interested in buying a Vero 4K and I’m curious if 3rd party remotes are supported out of the box or if those would require configuration on my part. Specifically, the Minix Neo A2 Lite would be the remote I’d be interested in, as it has a Gyro Mouse function that I think would be handy for skipping to a specific part in a video.
Also, I’m curious about the DVB-T2 module that’s offered in the store. Does it make us of an internal antenna or is it something I plug an antenna cable into? I’m currently using a cable that looks like this to receive my TV channels: https://i.imgur.com/NIqI074.png
Is this supported by the dongle? Thanks in advance!
