Running defaults settings with latest Leia alpha release. Kodi is reportin source is too slow, every 10 or so minutes it starts to stutter/buffer or pause to buffer.
Format : Matroska
Format version : Version 4 / Version 2
File size : 53.7 GiB
Duration : 1 h 55 min
Overall bit rate : 66.2 Mb/s
Movie name : The Post 4K
Encoded date : UTC 2018-04-14 22:33:47
Writing application : mkvmerge v22.0.0 (‘At The End Of The World’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 61.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.310
Kodi reports source is too slow.
Stream size : 49.9 GiB (93%)
Writing library : ATEME Titan File 3.8.13 (4.8.13.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
