I’m having some troubles getting HDMI pass-through working to my Onkyo NR686 AVR from my new Vero 4K+.
I believe I’ve got passthrough enabled, with all codecs, and I’ve disabled “Sync playback to display”.
Passthrough has worked previously for this file on my old Asus Chromebox 2955U version of kodi (openelec, kubuntu etc) to the same AVR.
I’m only seeing 2 channel reported from my AVR as input.
Thank for the reply - that certainly sounds like it will help.
I’m slightly surprised because I swear I had pass-through working for this file with my old kodi box - which was set to 2.0 channels because I read I needed to do this to enable pass-through (which then ignores the 2.0 setting). (I can’t find a good reference for this claim - and they’re probably relics of history now - but here’s a couple of bad ones: sound - Enabling 7.1 audio passthru in 14.04 for Kodi - Ask Ubuntu and Xtreamer Wonder Plus - though I was also battling pulse vs alsa issues back then. Anyway - I’ll fix the 2.0 setting now.)
So, to be clear - are you saying that 5.1 AAC can’t be passed through to the AVR, and must instead be decoded to PCM by the 4K+? The AVR certainly has AAC decoding capabilities when playing files - not sure about via HDMI.
