Hi.
Im on the latest OSMC build for Leia/18 and have some issues with 4k material. Some files play fine, others won’t show. These files all play fine on latest OSMC/17.
Display resolution switching seems not to work properly. The files are playing but the TV loses the HDMI signal. It makes no difference, if resolutions in settings are active or inactive. Logfile shows this:
20:08:38.648 T:3207590640 NOTICE: Opening stream: 1 source: 256
20:08:38.648 T:3207590640 NOTICE: Finding audio codec for: 86060
20:08:38.648 T:3207590640 NOTICE: Creating audio thread
20:08:38.649 T:3207590640 NOTICE: Opening stream: 7 source: 256
20:08:38.653 T:3250582256 NOTICE: running thread: CVideoPlayerAudio::Process()
20:08:38.662 T:3174036208 NOTICE: running thread: video_thread
20:08:38.663 T:3250582256 NOTICE: Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, pass-through)
20:08:38.876 T:3174036208 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
20:08:38.968 T:4072796768 NOTICE: Display resolution ADJUST : 4096x2160 @ 23.98 - Full Screen (39) (weight: -0.000)
20:08:39.163 T:4072796768 NOTICE: VideoPlayer: OnLostDisplay received
20:08:39.453 T:4072796768 NOTICE: VideoPlayer: OnResetDisplay received
20:08:51.814 T:4072796768 NOTICE: VideoPlayer: OnLostDisplay received
20:08:52.036 T:4072796768 NOTICE: VideoPlayer: OnResetDisplay received
20:08:52.541 T:3174036208 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:09:10.111 T:4072796768 NOTICE: CVideoPlayer::CloseFile()
20:09:10.111 T:4072796768 NOTICE: VideoPlayer: waiting for threads to exit
20:09:10.113 T:3207590640 NOTICE: CVideoPlayer::OnExit()
20:09:10.113 T:3207590640 NOTICE: Closing stream player 1
another example:
20:11:45.141 T:3136828144 NOTICE: Creating InputStream
20:11:45.211 T:3136828144 NOTICE: Creating Demuxer
20:11:46.567 T:3136828144 NOTICE: Opening stream: 0 source: 256
20:11:46.568 T:3136828144 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
20:11:46.568 T:3136828144 NOTICE: Opening stream: 1 source: 256
20:11:46.568 T:3136828144 NOTICE: Finding audio codec for: 86017
20:11:46.569 T:3136828144 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp3float
20:11:46.570 T:3136828144 NOTICE: Creating audio thread
20:11:46.572 T:2741367536 NOTICE: running thread: CVideoPlayerAudio::Process()
20:11:46.579 T:3136828144 NOTICE: Opening stream: 0 source: 256
20:11:46.579 T:3136828144 NOTICE: Creating video codec with codec id: 173
20:11:46.580 T:3136828144 NOTICE: Creating video thread
20:11:46.582 T:2716201712 NOTICE: running thread: video_thread
20:11:46.585 T:3136828144 NOTICE: Opening stream: 1 source: 256
20:11:46.595 T:2741367536 NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
20:11:46.768 T:2716201712 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
20:11:46.950 T:3136828144 NOTICE: Opening stream: 0 source: 256
20:11:46.951 T:3136828144 NOTICE: Opening stream: 1 source: 256
20:11:46.951 T:3136828144 NOTICE: Finding audio codec for: 86016
20:11:46.952 T:3136828144 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp2
20:11:46.956 T:2741367536 NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
20:11:47.242 T:4072796768 NOTICE: Display resolution ADJUST : 3840x2160 @ 50.00 - Full Screen (40) (weight: -0.000)
20:11:47.428 T:4072796768 NOTICE: VideoPlayer: OnLostDisplay received
20:11:47.714 T:4072796768 NOTICE: VideoPlayer: OnResetDisplay received
Any advice for me?
