When connecting Transcend 3.5" 4TB HDD with external power supply, the disk is not detected and network disonnects
dmesg shows
[ 547.861477] usb 1-1.3: new high-speed USB device number 116 using dwc_otg
[ 548.003223] usb 1-1.3: New USB device found, idVendor=174c, idProduct=5106
[ 548.003258] usb 1-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 548.003276] usb 1-1.3: Product: StoreJet Transcend
[ 548.003291] usb 1-1.3: Manufacturer: StoreJet Transcend
[ 548.003305] usb 1-1.3: SerialNumber: W30189L7
[ 548.006602] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 548.008351] scsi host33: usb-storage 1-1.3:1.0
[ 549.003614] scsi 33:0:0:0: Direct-Access StoreJet Transcend 0 PQ: 0 ANSI: 6
[ 549.009074] sd 33:0:0:0: [sda] 976754646 4096-byte logical blocks: (4.00 TB/3.64 TiB)
[ 549.010340] sd 33:0:0:0: Attached scsi generic sg0 type 0
[ 549.010930] sd 33:0:0:0: [sda] Write Protect is off
[ 549.010968] sd 33:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 549.016549] sd 33:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 549.039332] sda: sda1
[ 549.047644] sd 33:0:0:0: [sda] Attached SCSI disk
[ 549.266345] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 549.280133] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 553.382480] usb 1-1.3: USB disconnect, device number 116
[ 553.401534] sd 33:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0 x00
[ 553.401587] sd 33:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 0b c1 9d 00 00 1e 00
[ 553.401613] blk_update_request: I/O error, dev sda, sector 6163688
[ 553.401809] sd 33:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0 x00
[ 553.401838] sd 33:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 0b c1 bb 00 00 02 00
[ 553.401858] blk_update_request: I/O error, dev sda, sector 6163928
[ 553.404351] blk_update_request: I/O error, dev sda, sector 0
[ 553.473266] sd 33:0:0:0: [sda] Synchronizing SCSI cache
[ 553.474200] sd 33:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driv
Tried both OSMC and OpenElec.
On OpenElect when connecting HDD, the system restarts and hungs during boot
