Hi all, I know this is not a new issue, however I was not able to find proper solution to my 5.1 audio problem so far, so I am a bit desperate ;). Recently I have upgraded from rp1 to rp2 and just can’t get ac3 5.1 pass-through to work.
5.1 AC3 pass-through works perfect with audio settings on RP1:
RPI 1
audio HDMI
output configuration - best match
speakers 2.1
stereo upmix - disabled
normalize levels on downmix - disabled
resample quality - gpu accelerated.
keep audio - 1 min
enable pass-through:
ac3 compatible receiver - ENABLE
ac3 + - Enable
DTS - disabled
RP2
the problem is that those settings don’t work with RP2
When I play ac3 5.1 content all I hear is loud noise.
when I disable ac3 comp. receiver but keep ac3 plus enabled, Audio works fine but only with 2 speakers and its a bit quiet
does anyone know any solution? maybe I need to change something in confg file?
I tried all different audio configs.
RP2 is a great update but without working ac3 5.1 is useless
I would appreciate any help.
kind regards
Bart
