A2dp output to HDMI?
Hi all,
I installed a2dp, and my phone pairs with the pi. All good so far.
The catch is that it only outputs to the headphone jack. I’ve selected the output to pi:HDMI, and I see the player and file info on the top right of the screen, but no audio via HDMI.
What am I missing?
Bump…
Is the TV off when this happens?
Hi Sam, no the tv is on.
A log and screenshot of audio settings might help
Aye Captain…
https://paste.osmc.tv/bobisiqepi
https://imgur.com/36NaLJF
I can give you ssh access via my dydns if that would be easier for you to explore directly?
That shows your home screen, but I can see your audio settings from logs.
Can you try selecting Pi Analogue and see what happens?
I doubt it will change anything, but it’s possible Kodi is somehow hogging the sink.
Also:
try amixer cset numid=3 2
May need to sudo apt-get install alsa-utils first
Pi: analogue makes no difference.
set amixer:
    osmc@osmc:~$ sudo apt-get install alsa-utils
Reading package lists... Done
Building dependency tree
alsa-utils is already the newest version (1.1.3-1).
osmc@osmc:~$ amixer cset numid=3 2
numid=3,iface=MIXER,name='Master Playback Volume'
  ; type=INTEGER,access=rw------,values=2,min=0,max=65536,step=1
  : values=2,2
osmc@osmc:~$
Still no audio…
So if I set amixer cset numid=3 1 then I get audio from headphone jack, same story if I set amixer cset numid=3 0.
I have to turn up the volume in aslamixer.
BUT if I amixer cset numid=3 2, I get no output.
Any suggestions?
Unfortunately not — it works here, although I can appreciate this is not much help.
Got it working!
Must be a receiver quirk because if i add this to config.txt hdmi_force_edid_audio=1 it works!
That’s odd.
Your display may be detected as a DVI display instead or their may be a hotplug issue.
