someone else is managing the LAN. And yes I realize that we have strayed a little from OSMC and I appreciate your assistance.
I ran wavemon again and I now have a bit rate of 19.5Mbit/s
honestly I think that the problems I have been encountering are out of my control but at least now I know its not a software or configuration problem as I thought it might be before.
These IP addresses are both class A IP addresses, which means you are on a huge network, certainly on one LAN which is part of a WAN, with many DHCP servers.
I would add that they are auto-mounted to /media/, but you can mount them anywhere you want in $HOME.
Under OS X I would recommend Cyberduck instead of Filezilla for SFTP connections.
If you only want to copy/transfer files, I would also recommend scp(secure copy) over ssh. And as long as you use sftp you already have ssh installed.
The scenario :
I have a file called “test.mkv” under /home/osmc/Movies on
The device which runs has the IP 192.168.0.10 on the LAN and has ssh service enabled.
I want to transfer this file to my macbook pro, my username on OS X is Cornellus and it has the IP 192.168.0.1 on the LAN. I want to download the file to /Users/Cornellus/Movies.
First we need to make sure ssh is enabled on OS X : System Preferences > Sharing > enable Remote Login
otherwise in CLI : sudo launchctl load -w /System/Library/LaunchDaemons/ssh.plist
Finally here’s the scp command line tool :
Open a ssh session like you would normally do to administer , then to transfer the file from to the macbook pro
But I would definitely recommend setting a static IP for the device running and setting a good explicit hostname at the router level. Then configure the /etc/hosts files on OS X to bind the hostname to its static IP in order to find the device by its hostname on the LAN.
I’ll try to make a HowTo on LAN configuration for optimizing administration and global experience on a home network.
