I just found the Lazy TV plugin and it’s great, but I want to launch it from the Home screen instead of digging through the add-ons menu to reach it. (I’m currently using the Amber skin if that makes any difference.)
Is this possible, and if so, could someone please explain how to do it?
Thanks in advance for any help.
I guess it makes a differnce, on OSMC Skin you can do so via
Settings → Appeareance → Skin → Settings → Home → Customize Home Menu
You can do it with the Amber skin. Have a look in the skin settings for some thing like “customise shelf”. Be sure to make LazyTVZ a favorite first though so that it shows up in the list of things you can add.
I had wanted to favorite it before, but the add-ons menu in settings didn’t offer any means to do so, so I was confused. I went back into settings and happened to notice the disabled add-ons category for the home screen. Turning that on and navigating to it allowed me to favorite the program, which made it appear in the add-to-home list.
Thanks.
