I have an attached SSD1306 display in i2c mode that is tested and working in Raspbian.
How to make it work in OSMC?
Reason: Would like to display the CPU temp.
There must be a manual or some overlay that your supposed to load in config.txt, basically without trying to sound like an ass is to google it
Well we all know that @toast never sounds like it
Seems this is a good starting point
Guess the only step that is different for OSMC is
Enable I2C and SPI modules directly with raspi-config tool
which I believe can be done via MyOSMC instead.
Being away from home, I was curious how to do this from the command line.
Add these two lines to /boot/config.txt:
dtparam=i2c=on
dtparam=spi=on
and this line to /etc/modules:
i2c_dev
AFAICT, this should be sufficient. Running lsmod
should show three new modules:
i2c_bcm2835 7201 0
spi_bcm2835 7817 0
i2c_dev 7009 0
Thanks got it to work. Was missing the config.txt and modules lines.
lsmod didn’t display i2c_bcm2835
As an added note, I needed to ssh in as root and figure that out also. And yes I googled that too.
And for those that say google it… I did spent way too much time doing that for this issue. There wasn’t entries for SSD1306 and OSMC. OSMC is not Raspbian.
So putting … Google it in a comment helps nobody unless you did the google and see that there is info there in the first place.
So thanks dilthedog.
Always happy to be of help. Fortunately, I have a Pi back home running Raspbian, so was able to figure out what raspi-config does.
Still wondering which of that step is not possible via MyOSMC?
I have no idea since my TV is far, far away. I was just curious to know what raspi-config does - and I hope it’s a useful reference for others.
raspi-config does nothing in OSMC. It is a raspbian command.
osmc@osmc:~$ sudo raspi-config
It looks like you’re familiar with Raspbian, or following a Raspbian tutorial.
OSMC is a media center operating system, and as such, we do things a little differently.
You should find all the options to configure your Raspberry Pi under My OSMC. If anything is
missing or you have any questions, let us know at https://discourse.osmc.tv
Indeed so. I suspect you missed the bit in post #6 where I said:
