Additional video addons and Pi can't se my network drive
Very new to this but successfully installed OSMC on my Pi. When I clicked Get More in video addons, it found over 300 but I don’t know what these are and the ones I want aren’t there? How do I get specific ones?
Also I expected it to find my existing videos and music on my PC via my existing network but I’m struggling to make this happen?
Any help would be very much appreciated.
Thanks.
John
It depends on the addon you want, some are listed in the Kodi repository, some are out there on the internet but you have to install them manually. If you know what addon you want then just put it into Google and see what comes up.
For The Pi to see your existing videos and music, you have to tell it where to go. This should give you a rough how-to but using the Confluence skin. If you are using the OSMC skin then the steps will be slightly different.
http://kodi.wiki/view/Adding_video_sources
Thanks for that. I was busy all day yesterday but will have another look tonight.
