After applying hotfix2026 everything is gone
Hello everyone
Vero V , OSMC May 2026 2026.5-2
Had info about update available but update failed so I found that hotfix needs to be applied in order to get update. So I did and after update all my settings, add-ons are gone basically like I have brand new device. Tried to go to my addons perform check update , same with my repository, perform few reboots and still non of my addons are back, even firstly my time zone was wrong.
I didn’t perform backup because wasn’t that someone mentioned that.
Hoping that it’s easy way to get everything back.
Anyway log is
URL:https://paste.osmc.tv/syenazepi
There is no logs found at that url. Did you maybe copy that down wrong? As for your issue I don’t see how the hotfix would have done that. It literally only tweaks one file that tells the operating system where to get updates from. It doesn’t touch user data space at all. The time zone glitch is a known issue with some Kodi updates but that would not be related to your main issue either. Could you have accidently hit the option in My OSMC to reset your system? If so, then your setup has been wiped with no chance at recovery. The only other way I could see to explain why you might see a seemingly fresh install is if you added a profile and were logged into a user that wasn’t setup.
Strange for that log, that was on screen after I hit ok. After further going through all my addons with repositories are deleted, time zone ..everything.
Possibly I hit reset kodi option but one thing actually remained. Direct mount points (autofs) what telling that I wasn’t perform full reset, isn’t.
Anyway I will start from scratch slowly building everything.
@ darwindesign thanks for quick response
The reset in My OSMC is Kodi only. From what I understand it just deletes ~/.kodi (ie the entirety of Kodi userdata that is stored in the osmc users home directory) on next system boot. That folder missing when Kodi starts makes it rebuild it from defaults. If someone wanted a full system reset they would just do a clean install.
I have no insight about the log not getting uploaded. If that was the url it gave you it should have been there. The system is working as I used it just this morning.
Good luck on your rebuild.
