I have an issue with Gui Sounds on my Vero4k after I’ve updated it yesterday.
Audio Video Playback work just fine but I realized that the GUI sound stopped working however if I keep one of the directional buttons pressed causing a quick scroll through menu options (generating repeated sounds) after 2 seconds the sound returns but when I go back to a slower GUI sound generation they disappear again.
I can repeat it and as long as I’m generating GUI sounds at a fast repetition, gui sounds stick around but when I stop they are gone again after 2 seconds.
I’ve played around with the Setting/System/Audio settings and reset the audio values even but made no difference. Either the setting are the same as the previous version I guess so something else has change that it’s breaking this.
Any idea?
