Hi there,
Would it be possible to force audio received through AirPlay to another audio output than the default for movies without changing the default for movies?
Hi there,
I don’t believe this is possible
Okay, thx for reply.
Not 100% sure but I guess either the audio auto switch addon based on source could work. Otherwise you could do audio profile switch initiated from the ios device as soon as it start/stop to play.
https://forum.kodi.tv/showthread.php?tid=201896
https://kodi.wiki/view/Add-on:Audio_Profiles
Sounds cool, would there however be any way to switch the audio output direct through SSH without having to reboot?
Woop woop, the addon saved my life - thanks again!
