Alpha 3 - Script failed!: oscmsettings.update
When OSMC has loaded an the interface is fully visible I see this error:
I also see that the wifi does not connect and cec is not working. Maybe that is related to the error.
Any help is appreciated!
Note: When connected to wired network I also see this message, but then I have network access.
CEC is working perfectly since test build 1, probably something on your hand, tv setting is most probably.
WiFi issues have been resolved in Alpha 3
Same with the settings add-on.
You’re currently actually running a proposed Alpha 3 build. A lot has changed then. Hopefully Alpha 3 is not far off and should fix things up
Re. CEC: I’d recommend unplugging your TV for a full minute as this can cause some issues.
will the proposed alpha 3 build auto update to alpha 3 or will i need to re install?
great work by the way a very fast and smooth interface cant wait for the final product to be ready
i am also getting the
Script failed!: oscmsettings.update and a skin on when going back to the home
You’ll need to re-install
The script error has been fixed.
cheers sam if i re install to fix the error i am getting how do i keep my setting like library ect with out re scanning it all again? or is a re scan required again
I re-installed Alpha-3 (proposed) through the osmc-installer I downloaded last week, but I still see the script failed error on my wired installation a couple of seconds after OSMC has started…
Are you sure about this? I mean did you copy this error because oscmsettings.update must be osmcsettings.update
it could be a write error in the script itself
Hi guys,
I perhaps was a little unclear. I meant that when you install the proper version of Alpha 3, not the proposed version, you will see that this error is resolved.
The new Alpha 3 build should be out shortly.
cheers Sam
