I am trying to work with alsa as audio output since dsp only works with that, and i do need the volume amplification that only works when alsa is selected.
Now my problem is can i force alsa to output sound to hdmi and analog the same time?
so i am trying with omxplayer disabled and adsp enabled, and audio to HDMI & ANALOG and everytime i am trying to play a movie i get the crash sad face.
Disabling adsp get the sad face away but i have no volume amplification.
So to use adsp i am back to alsa.
Should i provide logs? If so please advise what kind of logs (full?).
To be honest I’ve never heard a report of ADSP working, so I’m not certain it does.
I’d remove it and try setting amplification from the audio settings OSD (when playing a video).
Increase it by 6 or 12dB and if you like it select “set as default for all movies”.
