Hi guys,
I’ve compiled the last version of amuled from svn and it seems to work.
Now I’d like to put a script in /etc/init.d so that it will start at boot but:
- how can I sure the mauled will run after the USB HD, where I have my download folder, is mounted/ready?
- how can I check the status of amuled? I copied a script that use:
status)
status_of_proc “$DAEMON” “$NAME” && exit 0 || exit $?
but it doesn’t exit with 0 when the amuled is not working (ei: crashed)
Do you have a working script?
