http://paste.osmc.io/kedepuweni
I’ve reinstalled OSMC because of this error, and now, 24 hours after doing the clean install, the same error again. I hope you can help me
Well on your clean install you also have installed some 3rd party repositories which might give the kodi based update trouble. Try it from the command line.
sudo apt-get update
sudo apt-get dist-upgrade
reboot
That’s weird.What’s the 3rd party repository? I don’t remember to have added anything to sources
Search your log files for “Using repository repository” then you will see which repositories are being used
But they are addons repositories, do they affect?
The commands you told me result on no updates found
https://kodi.tv/warning-be-aware-what-additional-add-ons-you-install/
Then you are up to date
