I have the lastest Version of OSMC on my RPi3. The Webinterface from Kodi runs on Port 8080. If I install apache2 it wont start and /etc/init.d/apache2 status gives out this:
root@pi:/# /etc/init.d/apache2 status
* apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2)
Drop-In: /lib/systemd/system/apache2.service.d
`-forking.conf
Active: failed (Result: exit-code) since Sat 2017-09-09 11:32:26 CEST; 7min ago
Process: 29536 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
Sep 09 11:32:26 pi apache2[29536]: Starting web server: apache2 failed!
Sep 09 11:32:26 pi apache2[29536]: The apache2 instance did not start within 20 seconds. Please read the log
files to discover problems ... (warning).
Sep 09 11:32:26 pi systemd[1]: apache2.service: control process exited, code=exited status=1
Sep 09 11:32:26 pi systemd[1]: Failed to start LSB: Apache2 web server.
Sep 09 11:32:26 pi systemd[1]: Unit apache2.service entered failed state.
I found this: Apache2 faild every time - Raspberry Pi Forums
Looks like the same issue and with osmc too. But there isnt a solution. But maybe that can help you to support me.
Thanks for your help.
