Hello support,
my RPi2B just updated to the Apr. 20th build: 4.14.78-4-osmc, but I have two issues now:
- the screen resolution change to 640x480 every time I restart RPi2B
- it is permanently running with load over 2
Is there any fix for this? Thank you.
That’s strange and should not be the case
Guess a addon issue.
Suggest to provide debug logs.
So, the load seems the issues after boot up, I need to be more patient and give RPi more then 10mins after start, after that, it went to normal: load average: 0.18, 0.12, 0.03
Seems it took more time to start of the latest built.
The bigger is the changing resolution
After install of new built it boot up in 640x480, so I changed it to FullHD and restart, but it boot up in 640x480 again. So, I login under Master user, changed it to FullHD and restart, but it boot up in 640x480 again.
I thought it depend on the TV resolution (connected via HDMI cable), isnt it?
Or is resolution saved in some config file?
Thank you.
