I recently upgraded from Gotham 13.2 to Helix 14.2 and found that my Logitec Harmony One remote doesn’t work the way it used to. The remote works, but the commands are all over the place. It seems to be emulating the AppleTV remote.
I pulled the file joystick.Harmony.xml from here and stuck it in the /home/atv/.kodi/userdata/keymaps without modifying it at all, but it still doesn’t work.
Thanks for any help.
Cheers,
Nico
What can I do to get it working?
