I have been trying to get Kodi to work properly for the past 3 weeks. Install was 3 weeks ago, video is good, but audio has frequent drop-outs - 0.5s to 1s every 30s to 180s… The display looks fine and smooth. My current config is as follows:
Raspberry Pi 3 B, with Ethernet connection to the router, NAS and TV (no wifi). Install was the version downloaded from OSMC 3 weeks ago - 17.02, something…, official raspberry pi 3 power adapter with 2.5A output
The video display is fine, but i get audio dropouts in both scenarios - HDMI output, and USB-Audio output. This happens for videos from my NAS server, and also for ‘live’ videos streamed from the internet. I have tried the following fixes as mentioned in the forum:
Change power adapter - I switched to another 2.5A adapter - no effect
Change refresh rate and video resolution - no effect.
Overclock CPU to 1.2Mhz, and memory up to 500 - no effect
Change the HDMI output settings - no effect.
I hope that you can help on this - video looks great, but video without good audio is terrible… uploaded the logs to http:/paste.osmc.io/xoguenone
<advancedsettings>
<cache>
<buffermode>1</buffermode> <!-- Default is 1 -->
<memorysize>157286400</memorysize> <!-- Default is 20971520 bytes or 20 MB -->
<readfactor>5</readfactor> <!-- Default is 1.0 -->
</cache>
</advancedsettings>
Note that the tags have changed compared to the kodi 16.x
That is what I use on my PI’s. the PI B+ and 2 use 52428800 as memorysize, as they have only 512MB Ram
Thanks - stupid question - How do I add those statement? I am using OSx - Do I do an SSH to the Rasberry pi? What do I use to edit? I don’t really know linux…
password is “osmc” (correction as per comment) too, and replace kodi.domain.sub by the hostname or the IP of the PI in your lan.
The go to the right directory:
cd .kodi/userdata
Then copy whe Advancedsettings content into your paste buffer and issue a:
cat > advancedsettings.xml
paste the buffer, once done, Hit Ctrl-C
and you’re done.
Check the content with:
cat advancedsettings.xml
it should show you the content you have pasted into.
To activate it, make a:
It’s better but still getting dropouts. I feel that the interval between dropouts is longer. Should I increase the size of the buffer? i.e., 209715200?
You are right. Still getting the audio dropouts… not clear what is going on. Version is updated - ver 17.02-2
All packages are up to date.
osmc@osmc:~$ sudo apt dist-upgrade
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
osmc@osmc:~$ sudo shutdown now -r -t 0
Connection to 10.0.1.21 closed by remote host.
Connection to 10.0.1.21 closed.
Tecks-MacBook-Pro:
Added the line into config.txt. Still getting audio dropouts, even with movies played from a usb plugged into he raspberry pi. Though i must say that is is less frequent now - i can get 1-2 mins interval wihout dropouts…
I got it to work, but I am not sure what i have changed :(. I will try to trace back over the next few days. It’s either a video/audio sync issue, or a hardware acceleration issue. Thanks for your help guys!
Now, if only i can get my K380 keyboard to work - need to reconnect manually each time.
Ok. I think i managed to narrow down the problem. I did a fresh install on a new SD card, updated to the latest version and incorporated all the changes recommended - it had dropouts on the fresh install with different file formats on the Pi usb (mp4 and mkv). After adding in all the recommended changes, it works now on HDMI output for sound wihout any dropouts! Video was workig all the time. My guess is that i did not put in the right hardware acceleration codes in the previous install (I forgot it was case sensitive).
However, I am still encountering audio dropout if I use the USB output on the Pi to my USB-dac. I am using an audio-gd singularity 19 DAC with an Amanero board. Any help is much appreciated!
