May I also ask about a audio issue? In System → Audio, I cannot use passthrough if I chose “Fixed” instead of “Optimized” or “Best match”. However, if I don’t chose “Fixed”, FLAC audio drops out each 2 seconds.
If I choses “Fixed”, it works with FLAC, but no bitstream audio, only Multi channel PCM.
Hi @Muyfa666 , I split your post from the thread you used and created a new one.
Please configure audio passthrough and appropriate audio codecs, reproduce the playback issue and provide logs. Here are instructions:
reproduce the issue
So, you’re using a DolbyVision P7 FEL video with a default FLAC, 16-bit, Stereo audio.
I tried to create something similiar, but I cannot reproduce such issue at all in my environment using a VeroV + Philips OLED910 TV + SONY STR-DN1080, EARC.
Can you provide a short clip of a problem video, let’s say around 3 mins? MKVToolnix is a friend to cut out such snips even from mkvs with included DolbyVision Full Enhanced Layer material.
dd is a Linux command to copy raw bytes.
If you are not using Linux but Windows on daily business, look for a tool which allows to split the first 1GB of such a video file in question and provide a link/method to share this piece of data. fsutil or gsplit seem to be populare Windows tools for splitting files.
Thx. Here your clip plays fine without any dropout or audio issue. The FLAC audio track has the ‘default’ flag set and was chosen by my player language settings.
Well, I’m not running the OSMC release but an experimental DolbyVision OSMC mediacenter version since DolbyVision profile 7 FEL is in preparation to get released.
Nevertheless a specific hw issue in your environment is still possible. Did it ever worked with your devices?
And why is this FLAC audio stream muxed into this rip? Your connected Samsung device claims to support all the other original high definition multi channel audio tracks.
But why you’re doing this? The connected Samsung device should be able to play all original audio tracks. Use the google translator if it requires a longish explanation. At the moment I assume the root cause of your issue more in your hw environment (perhaps by the high FLAC bandwidth used … who knows?).
