Nice! Would you share the asoundrc you ended up using?
Just scroll up.
Next we need to make dmixer the !default and dig into Jack a bit more to see about minimising latency.
Alright! Almost there
The dmixer device shows up in Kodi settings as ALSA:Loopback(). If I choose that I can play something else (with aplay) at the same time as Iām watching TV. Lipsync is OK but sound keeps dropping out so I think we need bigger buffers somewhere.
I am not as far along as you are. Iāve done the same steps but I am not getting: ALSA:loopback()
Instead I have loopback loopback PCM
Which provides no audio.
I also have the same error as you had before: connect(2) call to /tmp/jack-1000/default/jack_0 failed (err=No such file or directory)
jackd 0.125.0rc1
Not sure if this is something to be ignored.
alsa_in -j cloop -dcloop sometimes works but sometimes does not.
Furthermore jack_connect cloop:capture_1 system:playback_1
Does not return anything which I am not sure is a problem?
To be exact, mine says ALSA:Loopback(),Loopback PCM
I think that means Jack isnāt doing what it should.
Iām getting that even though itās working.
Did you add the line to /etc/security/limits.conf? I was prompted to do that when I ran alsa_in as osmc. (I had declined it when installing jackd1). Should be:
@audio - rtprio 99
Iām a bit worried that by trying pipewire you have messed something up. Have you removed it with --purge to get rid of any conf files? I believe itās Jack-compatible (ie itās a Jack substitute).
Doesnāt return anything here but still working.
I had accepted it during jackd installation but will look at the file tomorrow. Also I have started with a fresh osmc installation so no pipewire.
About the buffer isnāt that something we can specify in .asoundrc relatively easy? (In so far as any of this is easy)
Ps. I donāt have to do anything with jackd apart from the aforementioned things right? Like I donāt have to start it in some other way?
It just seemed to start by itself, here, but I did reboot after changing that file. Jackd1 doesnāt use systemd to start and I canāt find it in rcS.d either. Parameters are passed to it when you start it. It doesnāt have the equivalent of jack2ās jack_control.
Still learning.
I am still having trouble getting any sound. My cat .asoundrc is the same as yours. Did you do anything with /etc/modprobe.d/sound.conf ?
Lsmod | grep aloop gives me the following
osmc@osmc:~$ lsmod | grep aloop
snd_aloop 32768 8
snd_pcm 139264 10 snd_usb_audio,vc4,snd_compress,snd_soc_core,snd_aloop,snd_pcm_dmaengine
snd_timer 40960 4 snd_aloop,snd_pcm
snd 106496 28 snd_seq_device,snd_hwdep,snd_usb_audio,snd_usbmidi_lib,snd_timer,snd_compress,snd_soc_core,snd_aloop,snd_pcm,snd_rawmidi
just to be clear my .asoundrc is:
pcm.dmixer {
type dmix
ipc_key 1024
slave {
pcm "hw:Loopback,0,0"
channels 2
# the capture device Jack will listen to with alsa_in
pcm.cloop {
type dsnoop
ipc_key 1025
slave {
pcm "hw:Loopback,1,0"
had some trouble with the makeup of the quote but the idents etc are correct.
alsa_in -j cloop -dcloop works fine.
It seems to go wrong somewhere here:
- alsa_in -j cloop -dcloop -q 1 2>&1 1> /dev/null &
and finally make the jack connection:
as if its not connecting. if i run: speaker-test -t wav -Ddmix -l 3 -c 2
it doesnāt give errors but doesnt give sound either. In kodi I can select multiple loopback audio devices. none work.
Hmmm. Iāve just realised I was doing all my stuff on a rather old Kodi, Stretch and kernel 4.19. Apologies. Iāll try again on Matrix/Buster/5.x later but I have to go out shortly.
Alright thanks
Got this far. More later ā¦
osmc@pi3matrix:~$ alsa_in -j cloop -dcloop
connect(2) call to /dev/shm/jack-1000/default/jack_0 failed (err=No such file or directory)
jackd 0.125.0rc1
Copyright 2001-2009 Paul Davis, Stephane Letz, Jack O'Quinn, Torben Hohn and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK compiled with System V SHM support.
loading driver ..
creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Sorry. The audio interface "hw:0" doesn't support any of the hardware sample formats that JACK's alsa-driver can use.
ALSA: cannot configure playback channel
cannot load driver module alsa
attempt to connect to server failed
jack server not running?
Iām getting past that but still no audio. Running out of ideas.
Maybe I could simply solve this by getting audio out through analogue (3.5 jack) all tough the same dmix issues are likely to arrise I think.
NOTE: For ALSA 1.0.9rc2 and higher you donāt need to setup dmix for analogue output. Dmix is enabled by default for soundcards which donāt support hardware mixing. You still need to set it up for digital outputs.
Iām stumped. By using pulseaudio I can play multiple sound files at the same time using aplay piano2.wav for example.
however as soon as that happens kodi loses audio. When the files finish playing kodi starts playing audio again. If I select keep audio device alive = no in kodi settings kodi loses all audio output. I feel the fix to this is very close if I can just get kodi to use pulseaudio. But as osmc deprecated pulseaudio I donāt know if anyone can/will tell me how to do this.
CAESinkALSA::Initialize - Attempting to open device āsysdefault:CARD=vc4hdmi0ā
INFO : CAESinkALSA - Unable to open device āsysdefault:CARD=vc4hdmi0ā for playback
it wants to open sysdefault which apparantly pulse doesnt pick up?
Iām also still open to the jackd1 idea but I donāt know how to continue there either.
FWIW, Iāve been bashing away at the Jack solution, but just canāt get Jack to output to the RPiās audio device which is IEC958. Alsa can convert from LPCM to IEC958 with a standard plug, and I can get Jack to talk to that plug if I specify it when starting jackd. But alsa_in always fails. It seems to be bypassing the setting you put in the jackd call and always trying to connect to hw:0.
I imagine all you need for pulse is a suitable alsa.conf. IIRC Buster automatically puts a conf file for pulse in /usr/share/alsa somewhere and I think Kodi was recognising it until we took it out.
In other distros, pulse just muscles in and sets itself up as the default sink. It should be possible. All that should be required is a !default to override the vc4-hdmi.pcm.default in the cards directory.
yes i have a alsa.conf and a pulse-alsa.conf in there, but I am not sure where to move them to. the pulse-alsa.conf looks like a .asoundrc file but putting the contents in there doesnāt seem to do the trick.
Doesnāt matter where they are really but I think alsa reads them from the many places you can put them in a certain order. Iām sure .asoundrc must take precedence. That is, it only matters if you have ! override.
what should be the default this doesnt seem to work which is the pulse-alsa.conf:
pcm.!default {
type pulse
hint {
show on
description āPlayback/recording through the PulseAudio sound serverā
ctl.!default {
type pulse
to expand:
default
this is my aplay -L however kodi still uses sysdefault
Also I really want to thank you for your patience and trying to help me out. A lot of this stuff is really difficult for me to grasp.
more kodi log:
INFO : CAESinkALSA - Unable to open device āpulseā for playback
INFO : CAESinkALSA::EnumerateDevice - device sysdefault:CARD=vc4hdmi0 description vc4-hdmi-0, MAI PCM vc4-hdmi-hifi-0
Default Audio Device
INFO : CAESinkALSA::EnumerateDevice - device hdmi:CARD=vc4hdmi0,DEV=0 description vc4-hdmi-0, MAI PCM vc4-hdmi-hifi-0
HDMI Audio Output
It chooses the sysdefault one not sure if it would help if it would take the second one.
edit:
INFO : CAESinkALSA - Unable to open device ādefaultā for playback
this would seem to be the culprit as that is the pulse audio server. No clue why it canāt open it though
This may be the same problem Iām having. I donāt know how to address that vc4-hdmi.pcm.default (plug) device specified in /usr/share/alsa/cards/vc4-hdmi.conf. Certainly if you have a !default definition, alsa, kodi or pulse will never find it by the name default. What Iāve been attempting is making a copy of it with another name, something like this (and you can see things Iāve tried!)
# plug needed for default hw:0,0
pcm.jackdefault {
# @args [ CARD ]
# @args.CARD {
# type string
type plug
# slave.pcm "hdmi:0"
slave.pcm "default:vc4-hdmi"
# slave.CARD "vc4hdmi"
But thereās something about the args I donāt get. Is CARD 0 or vc4-hdmi or vc4hdmi?? Probably pulse and kodi work the same way - they look at all the alsa sinks on offer and try to open them. If successful they are listed.
Youāre very welcome. A pleasure to work with someone whoās prepared to put some work in to solve a problem. As I say, I can see other uses for the Jack connection if we can get it going. the problem with both Jack and pulse is 99% of users have X11 or some other desktop and thereās not much advice on command line operation.
Iāve made progress with pulseaudio. I can now have playback on kodi and simultaneously play another audio file i.e. piano2.wav however it only works if i use sudo aplay piano2.wav
aplay piano2.wav cannot play simultaneously. This leads me to a permission issue
osmc@osmc:~$ aplay piano2.wav
Playing WAVE āpiano2.wavā : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
osmc@osmc:~$ sudo aplay piano2.wav
osmc@osmc:~$
the first one doesnt actually produce sound while kodi is playing audio. The second one however does
I donāt know what permission to fix though the entire home folder is already owned by osmc.
Though for my initial goal of having alexa side by side with osmc kodi I can say that my problem is now resolved. I can run alexa with sudo and have simultaneous audio.
Now at some point I want audio to go through the 3.5 mm jack but for now Iām happy with it working through hdmi
