Hello,
since the last update from ~8.08. I can still change the Audiovolume from my Keyboard with the Multimedia-Keys. Is this a new feature or a bug? The 6.1 version tells me I can’t do such thinks if passthrough is activated.
Hello,
It sounds like passthrough is not being used. If you’re playing HD audio, then the dcadec library will be streaming this as PCM
Interesting, yes the actual video has PCM as Audio tells my AVR the Audio itself is coded as AAC 2.0 I will test a Video with Dolby next. I’m not sure but I think it worked befor on all Audio-formats.
Yes with an Video with Dolby inside it works as known, thanks for the help
