I am running 2x RBP2 at two different locations. They are using OSMC, installed from the installer about 2 weeks ago to play a directory full of movie trailers. They both seem to be randomly losing audio. Sometimes they play for hours without error, sometimes a whole day, sometimes only minutes. I have combed over the logs and it is not always the same file that causes the audio issues. I turned on debug logging and by the time I noticed it had happened again, the log had grown to over 700MB. I can’t even open the log file. I’m turning off verbose components logging and will wait for the issue to occur again so I can upload a (hopefully) manageable log file. In the meanwhile, here are the stats:
Device: Raspberry Pi 2
Installation media: SDCard
Connection: Wired
Power Supply Type: CanaKit 2.5A USB Power Supply with Micro USB Cable specially designed for the Raspberry Pi 2 (UL Listed) (from this kit: http://www.amazon.com/CanaKit-Raspberry-Complete-Original-Preloaded/dp/B008XVAVAW)
Power specs: 2.5A
Peripherals: No peripherals. Wifi module may or may not be plugged in, but is not being utilized.
Storage Device: Approximately 2-3GB worth of movie trailers in 480p, 720p, or 1080p mov and mp4 files are stored on the SD card. They playlist is being created via an autoexec.py script I will post below. I believe the issue is completely unrelated to this script.
OSMC version: 2015.07-1
XBMC version: 15.1-RC1 Git:Unknown compiled Aug 7 2015.
Codecs: none purchased
Audio/Video Output: HDMI for both, passthrough disabled.
Overclocked: Default osmc install settings.
Config.txt Extras:
gpu_mem_1024=256
disable_overscan=1
start_x=1
dtoverlay=lirc-rpi:gpio_out_pin=17,gpio_in_pin=18
disable_splash=1
hdmi_force_hotplug=1
hdmi_drive=2
hdmi_group=1
#hdmi_edid_file=1 (intentionally disabled)
autoexec.py
import os, xbmc
def get_filepaths(global,local):
file_paths = []
for root, directories, files in os.walk(global):
for filename in files:
filepath = os.path.join(root, filename)
file_paths.append(filepath)
for root,directories,files in os.walk(local):
return file_paths
pl=xbmc.PlayList(1)
pl.clear()
full_file_paths = get_filepaths("/home/osmc/trailers","/home/osmc/localonly")
for i in range(len(full_file_paths)):
xbmc.PlayList(1).add(full_file_paths[i])
xbmc.Player().play(pl)
xbmc.executebuiltin('xbmc.PlayerControl(RandomOn)')
xbmc.executebuiltin('xbmc.PlayerControl(RepeatAll)')
This script creates a playlist out of all of the files in /home/osmc/trailers and /home/osmc/localonly. The trailers folder is a btsync shared folder that keeps folders of 3 separate pi’s synced with a central computer. The localonly is a folder to place trailers that only play at that specific location. (i.e. one location is getting a title that another location is not, I only want to play that trailer at the first location.) These are uploaded manually via sftp on a location by location basis.
Apart from the install of btsync and the autoexec.py script, the only thing non-standard on the install is a script that opens up a reverse ssh tunnel and forwards the ports for btsync and ssh to it, so I can access to troubleshoot even though the pi is behind a firewall. The script is very basic bash. If it doesn’t find pidof ssh it creates one. It is executed every 60 seconds by cron.
It should be noted that a third RBP model B is also running the setup without audio issues. Version: 2015.07-1 15.1-RC1 compiled Aug 7 2015
Relevant portion of non-debug log while we wait:
09:17:41 81945.585938 T:1593832480 ERROR:
CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
09:17:43 81946.796875 T:1593832480 ERROR: Previous line repeats 1 times.
09:17:43 81946.796875 T:1593832480 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
09:17:44 81948.031250 T:1593832480 NOTICE: Previous line repeats 56 times.
09:17:44 81948.031250 T:1593832480 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
09:17:44 81948.031250 T:1593832480 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
09:17:45 81949.281250 T:1593832480 NOTICE: Previous line repeats 57 times.
09:17:45 81949.281250 T:1593832480 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
09:17:45 81949.281250 T:1593832480 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
09:17:45 81949.375000 T:1947202592 NOTICE: Previous line repeats 56 times.
09:17:45 81949.375000 T:1947202592 ERROR: ActiveAE::InitSink - failed to init
