I’ve got auto completion 2.01 installed, but with various settings (German or English, local or google), it reliably crashes osmc GUI - so I end up with a new login. What should I do?
OSMC 2021.11-1, kernel 5.10.78-2-osmc
Cheers,
Wolf
Cheers,
Wolf
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Thank you for your very detailled instructions!
Here are the logs:
https://paste.osmc.tv/ quonigesexu
No logs exists with that details, can you check again
I switched to the “estuary” skin in the meanwhile. Now, auto completion does not crash kodi; nevertheless, auto completion does not happen.
