Sometimes I deal with the problem that, after updating just one specific add-on to a new version, it stops working.
Hence my question: Does anybody know if it is possible, either via console command or even out of the OSMC GUI, to back up only one specific add-on, means the installed version, so that in case of failure it can be downgraded again?
I imagine that such a backup had to be stored either inside an existing or a new repository.
Up to now I work with full SD card images for that, however that is quite an effort for just one add-on to get it back to work again…
