Hi there,
Looks like there’s something wrong with creating backups from the OSMC configuration app.
Every time i manually or automatic want to create a backup i get the message “Insufficent diskspace at target location”
I tried different locations (usb and local network) for the backups but no luck. Diskspace is more then sufficent ofcourse.
Bug? or is it me?
I just backed up two Pi’s and restored them on new SD cards. I had setup osmc on random cards I had around the house after loosing 2 a few days ago, received the new cards today and backed up everything and restored it to the new Pi card and it went perfectly.
Just to note my backup was 1.2GB, this is of course with thumbnails etc.
I just ran into this same “insufficent diskspace at target location” error on the Vero 2 when running a backup.
The cause, as mentioned above, was due to insufficient space on the local nand drive, not the actual remote target drive.
After uninstalling 2 skins I was evaluating, and disabling the backing up of thumbnails, (to reduce the backup size), the backup completed successfully.
The error message is truly misleading. @Karnage
Rather than improving the error message would it not be possible to create the backup directly to the target location? That way one wouldn’t need to clear data off the SD card in order to generate a backup and it would also facilitate backing up of an installation were the SD card to go read only in a fault state.
