obviously I have a problem. From time to time, my remote controller keystrokes are not processed immediately by the kodi, but with a few seconds delay.
In order to find out what is going on I used bcmstat.sh script with –cxgM option, which reported constant %iowt between 25 and 60 while I am on the kodi’s main manu (I have just returned from an addon).
I have used iotop in order to see what is causing high io, and these two are the top:
Total DISK READ : 971.80 K/s | Total DISK WRITE : 0.00 B/s
Actual DISK READ: 571.02 K/s | Actual DISK WRITE: 35.47 K/s
TID PRIO USER DISK READ DISK WRITE SWAPIN IO> COMMAND
23577 be/4 osmc 21.59 M 15.08 M 0.00 % 77.37 % kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd [LanguageInvoker]
111 be/3 root 0.00 B 3.29 M 0.00 % 24.74 % [jbd2/mmcblk0p2-]
I am experiencing this type of problem somewhere from Semptember update (9-2 if I remember correctly).
While the problem is happening, in kodi log I can find:
11:58:24 66819.859375 T:1694188576 DEBUG: metahandler: ---------------------------------------------------------------------------------------
11:58:24 66819.859375 T:1694188576 DEBUG: metahandler: Attempting to retrieve meta data for movie: Memento 2000
11:58:24 66819.859375 T:1694188576 DEBUG: metahandler: Looking up in local cache by name for: movie memento 2000
11:58:24 66819.859375 T:1694188576 DEBUG: metahandler: SQL Select: SELECT * FROM movie_meta WHERE title = 'memento' AND year = 2000
11:58:25 66819.859375 T:1694188576 DEBUG: metahandler: Found meta information by name in cache table: {'rating': 8.5, 'year': 2000, 'duration': u'113', 'plot': u"Suffering short-term memory lo
11:58:25 66819.867188 T:1694188576 DEBUG: metahandler: Returned Meta: {'rating': 8.5, 'year': 2000, 'duration': u'113', 'plot': u"Suffering short-term memory loss after a head injury, Leonard
11:58:32 66827.039062 T:1694188576 WARNING: Attempt to use invalid handle 6
As iotop showed, the system reads/writes such a small amount of data.
How to trace this type of error?
All logs are on http://paste.osmc.io/ifopiviyan
(I haven’t restarted mediacenter in order not to loose the error).
