Is there possibility to open index.bdmv files on Vero?
Best regards
Doesn’t look like it, you most likely have to play the m2ts files directly
Thx for answer
Best regards
That’s basically a request to play back a BluRay with full menus. Kodi 17 (Krypton) is the current version, and it does not support BluRay menus. Kodi 18 (still in beta) has plans to support it, and posts on the Kodi forum show some success so far.
