Hi Guys
As per one of my previous posts I was having issues with my home 2x PI2 and fresh installed the latest version and did some modifications. Given my USB was the problem last time I installed them on the SD card but now the performance simply terrible when navigating through menus and when Art-work down loader running.
As per others posts all recommending to use the USB stick when I got MySQL server integration. Given I spend around 2 hours installing it on SD want to know answers to below 2 questions. I am sure other users will find it helpful as well
Without a fresh install, what is the best way to put the Kodi on the USB stick and let it run from the stick (smiler to fresh install from via the app)
Is there any performance tweaks I can do to only issue is Menu Navigation as most of the time OSMC - Kodi calling the MYSQL server to get the details
Thanks for your help and advice as always…
P.S:
If I can’t get a quick and easy win I will reinstall Kodi…
