Beta Build to Stable Release?
Thank you for all of your great work on OSMC!
I want to update to the newest Beta version, with the new background, but I’m wondering: would I need to do a fresh install when the stable version is released, or would I be able to update from OSMC settings as normal?
Please let me know when you have a moment. Thank you.
Provided you use official OSMC betas, and not @gmc builds, you won’t have any problems updating via My OSMC.
Otherwise, you just need to remove the sources.list entry, and then you’ll be fine.
