I have a RPi4 with OSMC installed, it’s now almost 2 years it was running just fine, I have upgrade it over the time with a 3A USB HUB, to be able to drive 2 HDD (2To full and 4To mid full).
Starting yesterday, it started to blackout during videos at always the same time on the videos. First I thought the video had codec issues, so I checked by downloading through FTP the video locally, and it was running fine, re-encoding it didn’t changed anything too. I started to check on multiple video files, and it was all the same, at a given time (different from a video to another) in the video, it will blackout video and sound.
I ran hdparm command to check the HDD if it had error, both HDD were fine with 110-120 MB/sec speed reading and no errors. Rebooting and clearing kodi cache didn’t work.
The log didn’t show anything obvious for me. I was finally able to get it to work again, by turning off the RPi, unplug every device, include the USB Hub, cut the power too, and wait 15-20sec. Then when booting again, the video were just playing good again.
I was wondering if someone have any ideas of what happened and how I could prevent it. Here the logs when a cut happened. Basically I cleared the log before launching the video and then stop as quickly once it blackout and read the log:
2025-02-28 21:07:11.220 T:511 warning : LoadTimers: Could not load timers file /usr/share/kodi/addons/skin.osmc/xml/Timers.xml: (Line: 0)
2025-02-28 21:07:11.265 T:511 warning : Skin has invalid include: Custom_Overlay_Debug_Grid_coords
2025-02-28 21:07:11.627 T:511 warning : JSONRPC: Could not parse type “Setting.Details.SettingList”
2025-02-28 21:07:14.011 T:667 warning : SetMenuLanguage - TV menu language set to unknown value ‘fra’
2025-02-28 21:08:54.844 T:511 warning : CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2025-02-28 21:08:54.844 T:511 warning : CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2025-02-28 21:08:55.219 T:511 warning : Label Formatting: $VAR[VideoPlayerChannelNumber] is not defined
2025-02-28 21:08:55.229 T:511 error : Window Translator: Can’t find window True
2025-02-28 21:09:15.018 T:825 warning : OutputPicture - timeout waiting for buffer
