I am looking to upgrade my current setup.
I currently have a Pi 2 with 16 GB Ultra which streams using NFS from my Windows box.
My aim is to build the same setup with a Pi 3 and put freeview, Amazon prime and Netflix on it. I also have quite a large collection of Blu-ray films, which at present I play using a PS3 (old and a little noisy.)
So my question is, “Can I add an external USB Blu-ray drive to play films on the Pi 3?” Obviously it would be wise to use one with an external power source.
- Does it matter which one I buy? ( https://www.amazon.co.uk/dp/B0194XV1ZQ?psc=1 looks good?)
- Will this plug and play or will there be config issues?
- I’m using genuine discs rather than rips or copies - can the Pi 3 and OSMC deal with transcoding the discs?
I have found a few posts relating to this, however I was hoping there was a how-to about. If not maybe we can put one together?
