There is an option to contact support from the menu above or you can email support@osmc.tv
by the way: before reinstalling i made a backup and when i wanted to install the backup again, there was an error message and now a lot of stuff seems not to work anymore… first of all my chosen skin (AEON MQ 8) didnt install and reinstalling it doesnt work (it stops while installing) and i cannot install other skins because of “missing dependencies”…
so it seems i need to resetup everything…
im pretty unhappy right now…
Some logs might help there. Also worth checking you’re installing the correct version of the skin
