Booting on osmc
Hello,
Just installed osmc from the NOOBS sd card sent by raspberry.
When booting, I get the following screen :wink:
Something wrong, but what ?
Sorry for the quality of snaps :frowning:
Thanks for your help
Let’s continue here from the Raspberry Pi forum.
  • Which image did you download from the OSMC installer?
  • Can you try deleting the image on your PC or selecting ‘Re-download’ when prompted by the installer?
Didn’t download anything.
i used the ‘official’ pre-installed sd card received from Raspberry.
Yes, I’ll do.
Soon for an update :-).
Thanks for your help Sam
You should use the installer from Download - OSMC
