Hi all,
I updated the OSMC software as suggested and it crashed halfway through the update, now its stuck in a boot loop? (Screen grabs attached)
I should have known better, i usually try and wait for updates because the longer you leave it the less chance you’ll have to install anbad update.
Any ideas?!
20180120_152154|690x388
It looks like your SD card may have failed. Try reinstalling on a new card, or test the current one.
This doesn’t look like a bad update but a bad SD-card. Best guess is your filesystem was corrupt before the upgrade and while files were upgraded this was detected.
Do you have a Linux system you can read the SD-card in and run an fsck on it?
