Never had issues before with buffering, but just started to watch a new TV show and in Episode 3 it started to buffer. Got a 720p version and that was fine.
It just takes ~20 seconds to start playing and then buffers continuously.
Rebooted the Kodi. Other 1080p files play fine, so don’t think it’s a network issue. Connected wired 100mbps to my NAS using NFS.
The “faulty” 1080p file plays fine from my Windows machine in VLC. It does have a bunch of audio streams and subtitles.
Media info can be found here
I’m on the latest update, it’s a Vero 4k.
reproduce the issue
Does it play from a USB Stick/Disc?
Did you try remuxing it with mkvmerge for example to see if the container has an issue maybe?
