Hey gang, in using OSMC on the latest update… I have buffering issues playing a movie from a USB Thumb Drive attached to my Pi 3…
Did not have buffering before the last update… is there a way to increase the buffer??
Thanks…
Kody
Thanks…
Kody
You may want to check if something is using all the CPU. SSH in, and run top to see what’s using the CPU.
Of course, log files would be useful! How to submit a useful support request - General - OSMC
Thanks… it was more of a curiosity… I will try and pull the logs… thanks…
I did not think that I would get buffering on play back from a USB thumb drive though…
I wouldn’t either, that’s why I suggested running top so see if something is hogging the CPU.
Check the file with mediainfo, had that the other day with a broken aac audio stream.
