Is there any way to call a specific ActivateWindow function from a plugin (python)? Similar to the custom menu that you have under the appearance settings.
I would like to call a plugin from my plugin, that’s why i would need it…
this is the command i would like to call:
plugin://plugin.video.torrenter/?action=customAction&url=/media/usb/folder/file.mp4
The actual programme that the plugin is for would use it to run different features. I don’t think there is a possible way for you to call the plugin with the use of code, even though you can do a lot of things with code.
Plus, trying to call a ‘plugin from a plugin’ seems strange.
Hahaha cool, no worries. Coding is made a LOT more difficult seeing as you have to use real terms such as execute, fetch and all that other mumbo jumbo
