Can Vero remote IR be programmed?
My TV does not have CEC support, so I can’t use CEC to turn my TV on and off though the Vero. Was wondering since the remote has an IR transmitter, if one of the buttons could be programmed to the power button of my TV’s remote?
The Vero remote does not have a IR transmitter it is only using RF
Oh really? Then what is the purpose of the little dark red plastic cover on the top of the remote?
Well on the one hand I assume a generic remote template being used that would allow a IR LED behind it and also to see the pairing led.
It’s an indicator light and to look like a traditional remote. There is technically an IR component but it isn’t used for IR.
I see, thanks for the info. Hopefully I can upgrade my TV to one that supports CEC soon.
